Headers too close to brake lines
Old Jul 16, 2001 | 10:33 PM
Alan84TA's Avatar
Ok, I'm putting on a set of TES headers on my '84 TA l69. I have them on and everything bolted up. Then I realized how close they are to the brake lines. I unbolted the stearing shaft and moved 2 of the 3 lines to the other side. The one in the middle though (goes along the crossmember to the other front wheel) runs right under the header with only about a half inch clearance. Is this enough? how about if I put some header wrap around that area? I can get to the bolt that holds it to the cross member or I might be able to get it out of the way. Else I'm going to just cut it out and run another one (argh)
Old Jul 17, 2001 | 02:10 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
I've seen less clearance then that, and been fine. Run it!!!
Ya can't have too many fast Chevys!
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
