SES light
Old Mar 17, 2005 | 10:34 AM
87camaro kid's Avatar
Car: 1987 Z28
SES light
ill be driving my car for about 15 mins and as soon as i stop at a light or soemthing for a min the ses light comes on and stays on but whn i turn the car off and back on its off and stays off untill i stop again for a few min what is causing this?
Old Mar 17, 2005 | 10:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The ECM. It's unhappy about something.
What's the code(s)?
Old Mar 17, 2005 | 10:49 AM
Car: 1987 Z28
i dont have a scaner so i dont no
Old Mar 17, 2005 | 10:52 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
You dont need a scanner you just jump the diagnostic terminal under the dash.
Old Mar 17, 2005 | 10:57 AM
Car: 1987 Z28
how do u do that?
Old Mar 17, 2005 | 11:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml bottom of the page
Old Mar 17, 2005 | 12:08 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Check the Manifold Differential Presure Sensor
Thats what mine was doing too.
Old Mar 17, 2005 | 01:14 PM
Car: 1987 Z28
exhaut manifolds? i have headers now...where would the sensor be?
Old Mar 17, 2005 | 01:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Forget that sensor for a minute. That sort of thing is merely a descent into "maybe it's this, maybe it's that, I'll just start replacing them both" hell. You'll NEVER get the car running right that way; most likely, you'll end up buying a whole car one piece at a time by taking that approach, and the very last piece will turn out to be the one that's been broken all along.
Start at the beginning, which is, ask the ECM to confess what exactly it is complaining to you about.
Step 1: What are the error codes?
Old Mar 17, 2005 | 02:11 PM
Car: 1987 Z28
im geting code 23 and 33
just to make sure i did it right...it blinks once then pause the blinks 2 times which equals 12? after it does thast 3 times it will blink 2 times then pause then blink 3 times to equal 23? and it did that 3 times and then blinked 3 pause then 3 to equal 33?
when i was doing this the fans also came on
Old Mar 17, 2005 | 02:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, that's exactly right.
So, look up on that list, and see what those codes are.
Remember, the codes don't mean "replace the so-and-so"; they mean that whatever the ECM is seeing from those things, doesn't make sense. So for instance a code for "rich oxygen sensor reading" doesn't mean "change the oxygen sensor"; rather, it might mean you have a very leaky injector. And so forth.
Old Mar 17, 2005 | 02:58 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
23. Low temperature at manifold air temperature sensor
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
Sounds like you forgot to reinstall a few sensors after installing a cold air intake.
Old Mar 17, 2005 | 03:12 PM
Car: 1987 Z28
i dont have a cold air intake i have the maf still hooked up and the stock air box
and i got rid of my air pump cause i have headers but i never got the code till now...i jsut rebuilt the motor
Old Mar 17, 2005 | 03:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Low temp at air temp sensor = wire is unplugged (makes the ECM see "absolute zero"; similarly, the wires shorted would make it see "surface of the sun") Find the wires and hook them back up
This being a 87, it'll have a MAF; so disregard the MAP thing. It doesn't apply to your car. That code list covers a variety of year models and cars.... they re-used the same trouble codes, there being only just so many 2-digit numbers, but gave them different meanings. Check your MAF wiring carefully, especially the plug where the wires plug into it. If that doesn't fix it, try swapping around the relays on the firewall; there's about 3 or 4 of them there, 2 of them control the MAF, and if you just exchange them all in the same direction (say, one position to the right, take the rightmost one and put it in the leftmost postion) and it either starts working right or something else goes wrong, then you know it's relays; if so, go buy one, and use it to replace them one at a time until you hit the bad one. The MAF might be bad, but it'd really suck to go buy some $300 part and it not fix the issue.
Old Mar 17, 2005 | 03:29 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
To test the maf you can simply tap the handle of a screwdriver on the assembly if the motor studders or dies bad maf.
Old Mar 17, 2005 | 03:32 PM
Car: 1987 Z28
where is the air temp sensor?
Old Mar 17, 2005 | 03:40 PM
Car: 1987 Z28
the motor hesitates when i give it gas from idle now to it was fine when i first ran the motor
Old Mar 17, 2005 | 04:59 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The MAT is under the plenum facing up. Right in front of the distrubuter.
Old Mar 18, 2005 | 02:12 PM
Car: 1987 Z28
its the 2 wires going into the plenum?
Old Mar 22, 2005 | 03:52 PM
Car: 1987 Z28
anyone? i had to redo those 2 wires cause i riped it out when i took the tpi off and i might have mixed the wires around
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
