dipstick atachment on edelbrock headers
Old Jul 16, 2001 | 05:20 PM
camaroguy99's Avatar
how did you guys get the oil dipstick tupe to bolt onto the headers? I've bent the hell out of mine and it's still like 2-3 inches from the mounting hole. any ideas would be great. thanks
Jim
Old Jul 17, 2001 | 12:09 PM
ttt
Old Jul 17, 2001 | 01:50 PM
Biochem's Avatar
Car: 2002 SOM z28
No, but if you find a way... Mine just kind of leans off to the side and I don't think the dipstick reaches all the way down...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jul 17, 2001 | 02:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use a spacer (pipe) the same length as the thickness of the original exhaust manifold minus the thickness of the header flange, use an original bolt. Put the spacer between the header flange & dipstick tube tab.
My Hookers came with it. Hearing all the "issues" people have had with TES & Hedmans, I'm not minding the extra $45 I paid for mine.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 17, 2001 | 03:10 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I used a spacer on mine but also had to do some 'adjusting' of the tube to get it to look good. I did mine on an engine stand though, which made it much easier to see what I needed to do. If you massage the tube a bit and get it completely seated into the bore that it goes into before you bolt up the passenger header all the way, it should line up decently enough to get a bolt through it and into the head. I think I ended up using one of the existing manifold bolts for it as well. So it is possible to get it bolted up to the header instead of using that gay lookin clamp thing they provide with the kit....... just gotta mess with it a bit .
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Hotchkis STB.
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
toronto formula
Sep 10, 2015 07:31 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
