New Parts
Old Mar 18, 2005 | 04:56 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
New Parts
I am not sure if this is where I should post this but I am going to anyway. I just recieved a few new part for my car and figured I would share them
New SLP Plenum Runners
New MSD Blaster Coil
K&N filter for custom CAI
I do have a question about installing the SLP runners. Reading the instructions it says you have a lot of cables and hoses that need to be disconnected to istall these runners. Can't you just unbolt the factory runners and then slip these down into place then tighten them back down. Let me know from anyone who has done this already.
Old Mar 18, 2005 | 08:29 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Not appearance and detailing related... maybe general engine so I'll move it there.
Old Mar 18, 2005 | 08:33 PM
Gambit69's Avatar
Okay. I wasnt sure where to put it. Since it will be apperance related once they are on but thanks for moving it to where you think it should be posted.
Old Mar 18, 2005 | 10:56 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Re: New Parts
You'll have to disconnect things like the throttle/TV/cruise cables from the throttle body and various connectors that attach to the plenum (two vacuum ports on the pass. side and the MAT on the underside of the plenum).. The plenum comes out first, then you can work on the bottom bolts to the runners.. Don't forget the bolts that go into the runners the opposite direction! You might end up having to undo the injector wiring if it gets in your way, but maybe not...
Old Mar 18, 2005 | 11:08 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Did you convert to SD or are you replacing the entire canister with the cone filter?
Old Mar 19, 2005 | 06:16 AM
thirdgen88's Avatar
Car: 1995 Corvette
Hopefully he knows that he has to keep his MAF as part of his custom cold air intake...
Old Mar 19, 2005 | 06:59 AM
Gambit69's Avatar
No I didnt convert to SD and yes I do know that I need to keep the MAF. I already have the design for the CAI that I got from someone on here already. Just need to get the piping for the CAI then I can put it all together.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
