Advice for newbie.......Smog crap
Old Jul 17, 2001 | 05:02 PM
sonasi's Avatar
How do I go about removing the smog crap from my 84 Z28?? I just want to make sure that I don't do something that I would regret.
Scott
84 Z28 305
Old Jul 17, 2001 | 05:10 PM
irocbsa's Avatar
You can take the air pump off no problem. Just unbolt it fromt its bracket, remove all the hoses and plug the stuff coming off of the exhaust manifolds. The belt for the air pump doesn't drive anything else so you can just throw it away, or hold onto it if you want.
bsa
Old Jul 17, 2001 | 05:31 PM
iroc5speed's Avatar
you'll want to cap off the air tubes to take the whole thing off too. Or you could just ditch the stock manifolds and go with some headers that don't have air tubes.
Old Jul 18, 2001 | 07:31 AM
sonasi's Avatar
What is the best way to cap off the tubes coming from the manifold? Also, isn't there a tube on passenger side of compartment that runs to the back and behind the engine? I assume it ties back into exhaust system somehow?? What do I do with this?
Scott
84 Z28 305
Old Jul 18, 2001 | 02:03 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
That line going behind the engine should be going to the catalytic converter. You should be able to cap it off.
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old Jul 18, 2001 | 03:05 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
1/2" pipe cap-offs work well. The fittings that the check valves normally thread onto are standard 1/2" pipe thread. The one in the back that leads to the converter is also a 1/2". You may want to remove those stainless steel pipes from the manifolds themselves as well. To cap off those holes you will need 8 1/4" npt block off fittings. A friend of mine just did this mod and his engine bay looks really nice now. Removing the entire AIR system really does wonders - it probably runs cooler in general now as well, due to the increase in airflow over the engine itself.......
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Hotchkis STB.
Old Jul 18, 2001 | 04:12 PM
sonasi's Avatar
Thank you all! I plan to follow everyones advice. I removed the belt to the pump and she seems to run better already!!
Old Jul 19, 2001 | 11:35 AM
Matt87GTA's Avatar
Just to clarify, the fittings in the manifolds are 1/4" npt and you will need 8 of them. I just reread my post and I even confused myself a little bit.... ...... doh....
Old Jul 19, 2001 | 01:00 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Hey that must be some friend that did that to his engine bay. I bet that the valve covers look really good probably even better than a certain persons really stout 355. Actually I am that friend it makes a HUGE difference I would say get rid of the WHOLE thing AIR tubes and all it will clean up the engine bay nicely. I am glad I did it. Thanks Matt.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
