ok which cam
Old Mar 20, 2005 | 11:03 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
ok which cam
i have a t5 so i want more hp than trq. i also want better gas mileage. so help me choose please. should i get the comp cams magnum which is rated a 2-6 or 25-65, crane energizer 2-5 22-52 the crane power max 2-5,22-52, or finally the summit, 2-45 or 22-52. these are all hydno roller, i am doing this because i had a collapsed lifter which we also think wiped the lobe. this engine has the 202 heads edelbrock performer intake and carb rated at 600cfm hei dist stock rocker arms stock oil pump and pan do not know what type of pistons.this is a mild engine its not a built up engine like the one in the elco. so witht his given info which would you choose and why. also do you guys think i should put a new timing gear set?
Old Mar 21, 2005 | 04:37 PM
jocww's Avatar
got a lunati one hopefully it will be good.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
