Water Temp Gauge Jacked Up
Old Mar 21, 2005 | 07:33 AM
89_LT1_IROC's Avatar
This past summer, my water temperature gauge started acting a little weird. When you go to crank over the car, the temp gauge needle stands straight up and remains there after the car is started. I took the cluster cover off, and I can unlodge the needle, but it just does it again the next time I start the car.
At first, I thought it may have something to do with the LT1 swap / wiring, but after talking to my friend's dad who has an 88 stock IROC, I realized that it might be a problem with just aging gauges because his is also stuck completely vertical.
Anyone have any suggestions?
Old Mar 21, 2005 | 12:57 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
what if you put somthing blocking it from going straight up ? say at the 260 mark put a pin so it cant pass it
Old Mar 21, 2005 | 01:11 PM
Yea, I thought about that, but Im not sure exactly how to go about it. Like, how would it be attached? I was wondering if maybe I could pull the gauge out and maybe check the 'inards' of it for something.
Old Mar 21, 2005 | 01:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could try a filing a little on whatever it's catching on.
Old Mar 21, 2005 | 04:07 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The gauge sending unit is broke or the wrong kind. Get a new one that works for gauges, the idiot light one is different and will do exactly what your's is doing.
Old Mar 21, 2005 | 06:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It sounds more like the needle is swinging too far and getting stuck when the key is turned past the bulb-test position, more than a problem with the sender.
Old Mar 21, 2005 | 06:22 PM
Engine: SBC, LS-x
That only happens when somebody has been in there and run thier fingers around the gauges like a bull in a china shop.
Look for sighns first before dismanteling the cluster.
Bet it's the sensor being wrong.
Old Mar 21, 2005 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Or when the gauge gets old.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86IROC112
Sep 11, 2015 04:04 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
