Sway bar!!! Front
Old Jul 18, 2001 | 11:00 PM
MR. JORDAN's Avatar
Sway bar!!! Front
Is it safe to run you're vehicle without swaybar's. I'm in the process of changing bushings>>>...
Old Jul 19, 2001 | 12:12 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
That depends on your definition of safe. It won't turn worth a darn, way too much body roll. But I suppose if you're careful not to wreck...
91 Z28
Come see The Vicious...
Old Jul 19, 2001 | 02:55 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
won't turn worth a darn?
dude, lay off the crack pipe all the swaybars do is prevent body roll..
you'll notice that the car will tend to lean quite a bit, as long as you take corners at a decent speed you're fine..
my Dad's 72 big block truck doesn't have swaybars, nor did my '68 Camaro and they were just fine..
Webmaster: www.IROC-Z.org
Old Jul 19, 2001 | 11:24 AM
Brian K's Avatar
It actually helps to have it off in the fornt for drag racing too...
Old Jul 19, 2001 | 07:49 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Cars that lean quite a bit tend to not turn worth a darn.
I was going faster than I'd ever gone before but then I fell off.
Old Jul 19, 2001 | 08:05 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
To answer your question a bit better - yea it's safe although don't push the car too hard because the handling will be a mess if you've got just the front disconected as your question seems to indicate.
But then you won't be driving too fast anyway because it's still snowin up there - right?
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
ProtoMaster22
Aug 26, 2015 07:50 AM
