ls7
Old Mar 24, 2005 | 12:24 PM
  #51
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Not true, use the search button and look up just about anything posted by Therckid.
Old Mar 24, 2005 | 12:31 PM
  #52
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
but d00ds,.. i can it fro cheap,.. seroously d00ds,.. all most fro free,.. & its a big block toooo,...
where has he been at lately? i need a good laugh.
we put a bone stock LS1 in a very clean 68 camaro, it came out nice, runs great, gets much better fuel mileage than the radical carbed 350 it had.
a LS7 in a third gen, or any car for that matter with twin turbos,.. Jay Leno has one. WOW,.. what a rocket ride, i don't think its a ride i would take,... well, maybe once, but never on the street.
Old Mar 24, 2005 | 12:35 PM
  #53
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
why dont you just call Jay Leno.. and ask him.. since he was the 1st one to use the LS7 and Twin Turbo it.. which is where i think you got the idea.
good luck trying to get an LS7 now. If i were you.. i would use the LS2, and twin turbo that. or go to SLP and get their 402ci engine for far less.
Old Mar 24, 2005 | 01:09 PM
  #54
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
jay leno also has a motorcycle with a Blackhawk helicopter motor
Old Mar 24, 2005 | 01:23 PM
  #55
DENN_SHAH's Avatar
yep, the Y2K,... Jay Leno has everything,.. except for maybe the BossHoss.
Old Mar 24, 2005 | 01:46 PM
  #56
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Originally posted by jojo22
its not about too much 2 handle its about haveing something all others will look up to and admire while still being able to ride around in it
Nobody will look up to you that wouldn't with just a 400hp street motor. A car thats fast is one thing, but without the ET, its just a dyno queen and any drag racer is going to think your an idiot throwing that much in a motor that runs 12's after almost hitting the wall 3 or 4 times.
http://www.racingjunk.com/exec/ca/vi...ssifiedad.html
If you must have a 1000hp street car/dyno queen buy this or copy his setup. The ls7 would be nice, BUT you gotta think realistically here, not to mention you could do about as well in hp for a lot less money.
Old Mar 24, 2005 | 02:05 PM
  #57
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
well jay lenos car uses a prototype ls2 block. it is 425ci, as opposed to the ls7 which is 428ci. basicly the diff in displacment comes from .015 bigger bore on the ls7. lenos motor uses a forged crank and the ls7 uses titanium.
Old Mar 25, 2005 | 10:36 AM
  #58
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
actually lenos TT olds tornado is based off an LS6 block from the CTS-v race program...i know becasue i have the mag that the car was in...the heads are CNC'd LS6 casting aswell as a undisclosed camshaft
Old Mar 25, 2005 | 01:43 PM
  #59
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
read the magazine again. notice it says it is a gen IV sbc? the heads are from the cts-vr program. it says the engine is based on the ls6 architecture, but it is a prototype gen IV. the heads are also gen IV. if you were to read in the oct 04 issue of hotrod you would see that the cts-vr does not use a ls6, it uses a c5r motor with 104.8 bore and a 83.0 stroke. considering the heads are based off the cts-vr program and the cts-vr uses a c5r, then lenos car could not be useing an ls6 head, when it was stated the it uses cts-vr heads, which are c5r heads.. and if you realize that the ls6 is a gen III motor and it says the motor in lenos car is a gen IV the it would be impossible for lenos to be a gen IV and an ls6. you were wrong, you should have reread the article.
Old Mar 29, 2005 | 09:25 AM
  #60
ugk's Avatar
ugk
Car: 91 Camaro RS
The only titanium the LS7 uses is with the connecting rods, the crank is forged steel.
meeklay812
Oct 1, 2015 03:46 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
Iroc You
Apr 8, 2008 08:46 PM
