This never happend to me before! Why and is it normal?
Old Jul 19, 2001 | 10:15 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ok so my car has been a little hard to start so I go to bump the timing back a little "it helped" But any way well I was in the adjusting mood I decided to advance the timing to see where It would start pinging and then back it off and reset it. I got it full advance with no idle ping "all the way to the manifold" and gave it a little rev to see if it would ping like a motha. Well to my supprise the exhuast started blowing out white smoke??? Whats up with that? non cc carb.
SSC
Old Jul 19, 2001 | 10:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
It won't ping at idle, only when you put it under load. It could be way out and you would never know it.
Sometimes it won't even ping with a snap of the throttle.
This is why they make timing lights.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 19, 2001).]
Old Jul 19, 2001 | 10:54 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yeah, this has to rank as the funniest thing i heard all week. I can't oofhand of anything you could have broken though for the white smoke w/o actually loading the engine though.
But yeah, the old 'advance till it pings' means atfull load WOT operating temps, normal gas. Not see how far you can turn the distributor till it fires the wrong plug, lol.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
