Oil pressure
Old Mar 22, 2005 | 05:32 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Oil pressure
My engine has had almost zero oil psi at warm idle for over 10 months and a max PSI of 20 on the highway.No knokcs or ticks and i drive the **** out of it daily.Now I tried 20w50 oil in her and the PSI did not change at all not warm or cold.Is this a signt hat maybe my pickup is clogged? or maybe my oil pump is toast.Next im going to do a oil change with straight 80 and see what happens.The motor also has over 280,000k with plenty of power.Btw these psi readings are from a aftermarket mechanical gauge.
Old Mar 22, 2005 | 05:42 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Most of these cars at idle have around 10psi, and under load or higher RPM 40-50 psi. Could your guage be faulty?? Also I don't recommend 20w50 for these cars at all. 10w30 at the most. I personally use 5w30 only. Your pump may be getting weak at that milage, but I would try some thinner oil before anything thicker. See how that works for you and go from there.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
