dose this sound good???
Old Mar 22, 2005 | 09:41 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
when I get back from Korea, I plan on doing a build up on my '84 camaro Z-28...hears what I plan to do to it.
-bore block minimum that I can (it's already .030 over)
-speed pro forged flattop pistons W/ anti friction coating
-total seal gappless rings
-eagle H-beam rods
-stock forged crank(already have)
-trick flow 64cc 23* heads W/ CNC combuston chambers and 2.02/1.60 valves, port matched to intake (already have)
-edelbrock pro-flo 1000cfm EFI, port matched to heads(already have)
-trick flow cam, TFS-31402001, see http://store.summitracing.com/defaul...402001&FROM=MG for cam specs
-retrofit roller lifters, comp cams p/n CCA-853-16
-behive valve springs (to match cam when they reply to my E-mail)
-rev kit
-edelbrock gear drive (quiet)
-MSD 6A
-hooker long tube 1 3/4 headers
-msd coil (already have)
-convert to T-56 (getting parts togeather as we speak)
-spohn T-56 crossmember w/ torque arm an D/S loop
-spohn 8 pt roll cage
-spohn "wonder bar"
-spohn panhard bar
-spohn A-arms
-Competition Engineering subframe connectors W/crossmember
-lake wood control arms W/ traction bar
-edelbrock strut tower brace
-nordskog digital panel
-digital dakota SGI-5 box for speedo conversion
-headlight/taillight/liscense plate blackouts
-SS style hood
-re-paint car metailc black
-black GTA wheels
-re-do intieior in black
dose this sound like a good setup, did I miss anything (I have allot of dress up parts on the engine already which I will re-use, also being in the AF I plan on safty-wireing the bolts(I've had problems in the past with bolts backing out)
Old Mar 22, 2005 | 09:48 PM
Engine: 383
by the way dose anyone know of a tubular K-member that will work with this setup, and being that I can't get a responce from comp or trick flow, which beehive valve springs should I use (I really want to try them)?
Old Mar 23, 2005 | 06:54 PM
Engine: 383
btt
Old Mar 23, 2005 | 08:20 PM
sellmanb's Avatar
Car: '86 Berlinetta
I like what you've got setup there... but one thing...
which is it, a stock cast crank, or a forged one? lol
Looks like you've had a lot of time on your hands
Thanks for serving our country, and I hope you make it back in one piece!
Old Mar 23, 2005 | 08:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stock in this case doesn't mean from a thirdgen.
Old Mar 23, 2005 | 08:38 PM
12secformula's Avatar
Car: 94 Z-28
The normal size would probably work....but I went w/ the next size up....26120's.
Old Mar 24, 2005 | 12:34 AM
Engine: 383
the block is a Mr. goodwrench "profromance" block, it was sonic checked before it was done .030 over, I'm hoping I can talk a machine shop into going only .040 over with it, the reason I want to do a re-build on it is I don't think the rings ever seated properly back when I origanally built it in '98 because it alaways had some blow-by, and just before I left it was starting to get really bad, probably because it had a set of no-name-brand forged pistons and rings the machine shop had "laying around" and I was a H/S kid w/ no $$$ so I went for it, and I don't think I followed the break in prociedures either...again I was a stupid H/S kid. The crank is a forged crank out of a early 70's truck 350 I had laying around in the back yard (the block was cracked where someone droped it), and I already have the 2-pice rear-main conversion flywheel for the T56. Also dose anyone know a good machine shop, paint shop and a good salvage yard(for the interior and T56 setup) in the Las Vegas area?...bear in mind that I will be returning to LV late Oct/early Nov '05
Old Mar 25, 2005 | 12:15 PM
Engine: 383
btt
Old Mar 25, 2005 | 10:54 PM
Engine: 383
also dose anyone have any exprance with a SS style hood that they would like to reecomend? I've heard bad things about ASCD hood coming apart while driving...I don't want that to happen to me.
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
BurlyChev
Aug 16, 2015 09:08 PM
mustangman65_79
Aug 8, 2015 12:07 PM
mustangman65_79
Aug 7, 2015 09:55 PM
