should I make my 305 and 327?
Car: RS
Transmission: 4L60
I was reading that if you put a 350 crank in a 305 you get a 327. Has anyone here done that and was it worth it. Would I have to get 350 rods? Would this give my 305 the same stroke as a "real" 327. I plan on rebuilding and putting it on a 100 shot of nos.
late model 91 rs
fully loaded t-tops, red leather
paint- gm red and yellow blend (light red)
custom painted 16" Camaro rims
305 tbi 14"x3" O.E, computer chip, accel super stock plug wires
Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: a lot of "family" cars, pickups, New v-6 stang, totally killed '86 SC Camaro.
late model 91 rs
vic_v8@yahoo.com
Car: Death Mobile
Engine: 666 c.i.
A 305 DOES have the same stroke as a 350 crank. If you stroke it with a 400 crank (3.75") and bore it .030" over, it becomes a 334.
A 327 is a 4" bore (same as a 350) with a 3.25" crank.
Car: 89 Iroc
Engine: 305TPI
I would have to say no on this one and go get a nice 350. I have thought about making a 335 or 334 (heard both) but I have decided to just get a Ram Jet 350 instead more power hands down than any 335/334
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
no, a 305 and 350 have the exact same stroke, which is 3.48 inches.
the bore of a 305 is 3.74 inches
350 is 4 inches
a 327 is a 4 inch bore with a 3.25 inch stroke crank.
350 is 4 inches
Transmission: 4L80E/4L80E
I don't know how these stories get started. You can't "make" a 327 out of a 305, as said above, because of the wall thickness of the casting. Even a 3.75" crank in a stock bore 305 block (good luck finding pistons for that off the shelf) make it a 328.7 cu in.
When you get right down to it, 280 hp out of a 305 cubes isn't that hard. But, if you're doing it with a 100 hp shot, be sure to do it right. Nitrous done wrong is bad for any engine.
By the way, factory SBC rods are all 5.7" long, except 400 which were shorter. Big end sizes did change, however, most 327's being smaller than all 350's and 305's.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by five7kid:
I don't know how these stories get started. You can't "make" a 327 out of a 305...
</font>
</font>
Sure you can... anything's possible with enough duct tape and bondo! Go for it
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
I keep forgetting the handyman's secret weapon.
Where's Red Green when you need him?
db057
Aug 11, 2015 10:11 PM
