Set timing in Neutral or Drive??
As the auto official idle speed is achieved in Drive rather than neutral, will a slightly better timing result be achieved setting it with the car in drive (it affects the reading 1-2 degrees)
The reason I ask this, my car runs perfect but is hard to start -sounds like it's starting "off beat" when warm (left for an hour or two) but will start straight away if only just switched off or totally cold. Not a starter issue; that turns strong.
I'm just wondering if a slight difference from N to D (about 200RPM between them) could make this much difference. Problem has arrisen ever since changing the distributor.
thanks
thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Neutral with the EST unpluged is the best way to set the base. The ECM will add timing based on your base setting.
