Vette heads
Old Mar 24, 2005 | 03:46 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Vette heads
Hi!
I have a deal on a complete engine from a vette-87 whith alu heads,are these heads a upgrade from my stock L98 heads?
And are the pistons different to?
Thanks for any replay.
Old Mar 24, 2005 | 05:10 PM
ede's Avatar
ede
the vett engine is a L98 so you wouldn't gain much
Old Mar 24, 2005 | 05:18 PM
sellmanb's Avatar
Car: '86 Berlinetta
the vette heads are aluminum IIRC. So you can run one more compression. You might as well just swap heads. You'll get the same results lol.
Old Mar 24, 2005 | 09:25 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The aluminum L-98 heads are a good head but in stock form don;t make any more horsepower than you stock cast TPI heads. So a straight head change won;t get you much of any thing.
But..... the beauti of these heads lays in their performance when modified.
When fully ported, deshrouded chamber, with larger LT-4 2.00x 1.56 valves They are a bang up head.
But it's up to you to do the mods or send them out to be professionaly ported.
You can get good results yourself.
Old Mar 25, 2005 | 12:25 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok Thanks.
I will get the complete engine becouse its cheap, and have the heads done,i think it will still save me some money compere to by a complete new set of heads.
The hole engine with ecm and harnes are 700USD.
Will it be worth just swap those ported vett heads without swap cam.My goal to next winter are 270RWH.
Anders
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
