How to tell if I'm running to rich?
Old Mar 24, 2005 | 05:55 PM
snisbet375's Avatar
Car: 1983 camaro z-28
Engine: 305 crossfire
Is there a way to tell if I am running to rich. I took off my exhaust the other day and there is a very strong smell of gas. The inside of the pipes near the header collector is very dark and oily looking. There is no smoke coming out of the exhaust, just strong exhaust smell. Is there anyway to prevent the strong odor? Would cats solve the problem. I dont have cats on my exhaust right now. Could this be the cause?
Old Mar 24, 2005 | 05:57 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
black smoke is normally a good sign, but you dont have any smoke?
Old Mar 24, 2005 | 06:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Spark plugs tell all. Know how to read the plugs?
Old Mar 24, 2005 | 10:02 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i dont, but am interested, could you explain it please?
Old Mar 24, 2005 | 10:10 PM
BOTTLEDZ28's Avatar
Transmission: A4
Im am not a professional at reading plugs but here is what I know. If the tip of the plug is solid black like soot then you may be runing rich. Some people even smell their plugs. if the plug has a white dry looking finish to it then your running lean. You want a plug that has a brownish gold look to it.
Old Mar 25, 2005 | 03:13 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
head to the library they shoudl have books that will even show you pictures of the plugs and what each one looks like under different conditions.
but yeah if your running white on the plugs tips your prolly running lean.
and blackish depending on how it looks can either be rich or oil.
tan or goldish color is what you want to see
as far as exhuast smells you can have a car running lean and still smell strong gas odor if the motor isn't burning the fuel it has right. so best bet is to check those plugs out it will give you better indication of how the motor is running
Old Mar 25, 2005 | 01:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look on the back cover of a Haynes manual, they show alot of different plug 'conditions' and what they mean.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
