Upgrading to Open Element, which to choose for 305
Old Jul 19, 2001 | 11:46 PM
un4givin89's Avatar
Alright I've heard alot of talk on this subject. I am most likely buying elderbrock with K&N filter, but I am not sure as to which size to get to replace my stock filter. A good part number refrence or link would be even better. What are some pointers when chosing??
___________
Two Camaros, and all the time
305 5.0 Black Un4givin 1989 Camaro RS
[This message has been edited by un4givin89 (edited July 19, 2001).]
Old Jul 20, 2001 | 12:13 AM
iroc5speed's Avatar
I think you should just go ahead and buy the k&n air cleaner, since you're not using the edelbrock filter anyways. if you have the stock hood, I would go with the 2 1/4 by 14 clearner.
Old Jul 20, 2001 | 12:37 AM
My305camaro's Avatar
The stock hood over an LO3 TBI will fit a 14X3 filter (non-drop base) no problem. You might want to check out http://www.ramairbox.com I might be changing from my open element to their setup in the near future.
1991 Chevy Camaro RS TBI w/auto
Mods:
Edelbrock TES Headers, REALLY high flow cat, 2 1/2 in catback flowmaster, 160 stat, hypertech chip, MSD ignition (rotor, cap, superconduct. wires), Bosch quad4 plugs, open air filter, all TBI mods, no smog stuff, no EGR, lots of suspention and alignment upgrades, and a big Chevy bowtie sticker on the back.
Fastest e.t.:
15.68 @ 87.3mph
Old Jul 20, 2001 | 10:58 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
14X3 non drop and toss that 1" spacer between TBI and stock airfilter. Just will fit under hood.
Old Jul 20, 2001 | 03:27 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by brharris27370:
14X3 non drop and toss that 1" spacer between TBI and stock airfilter. Just will fit under hood.</font>
the problem you are going to find with doing it that way is that if you remove the spacer you will not be able to get the 14x3 open element on, without it hitting the distributor/coil. I have to keep it on otherwise it is not raised enough to properly seat. I do however suggest putting a gasket below the spacer or something to keep it firm to the TBI. That way it is all induction and no waste.
Old Jul 20, 2001 | 03:59 PM
un4givin89's Avatar
Think I'll go with 14 by 2 1/4 juss to be on a safe side. Thanks guys
Old Jul 20, 2001 | 05:15 PM
NHcamaro's Avatar
don't forget those damn sensors
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
Old Jul 20, 2001 | 10:18 PM
CamaroBoy's Avatar
I'm doing this tomorrow as well. What sensors??
Old Jul 22, 2001 | 08:37 AM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
there is a small sensor attached to the bottom of the stock air cleaner. I believe it's a air temperature sensor. you can remount it in the knock out plug of your open element or just make sure it's plugged in and not interfering with anything. I had to put a new hole in my 9" because the K&N filter was just a bit thicker than the stock filter that came with the Mr. Gasket filter unit. The K&N number is E-3500. 9"by 3" w/ 7"inside diameter. $38.00 for the K&N $11.95 for the 9" Mr. Gasket unit. the car will throw trouble codes and not run well at all w/o that sensor plugged in.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
Old Jul 22, 2001 | 09:43 AM
94'_SS's Avatar
I replaced my stock unit with a 14" Mr. Gasket non-drop aircleaner and used a 14x3 Accel air cleaner and it works great on my 88' Firebird 305 TBI. My only problem is the breather filter right now is looking pretty crappy(stock pipe with stock breather filter)and I want to put a seperate breather filter on my valve cover but the pipe is stuck on the valve cover. Is there any trick to geting the pipe and gromet off the valve cover with out breaking them and having the bottom half of the pipe and gromet falling into my engine? And what size breather filter do I need to work on my stock valve cover? Thanks for the help.
Old Jul 22, 2001 | 10:36 AM
un4givin89's Avatar
Here is an guide to installing open element in your TBI
http://snflupigus.tripod.com/tech/op...tep1/step1.htm
Old Jul 22, 2001 | 12:58 PM
Guest
Guest
Posts: n/a
In the theme of responses of yours to posts by others:
Why dont you go buy a book on how to calculate the correct size and figure it out for yourself rather than asking dumb questions?
Old Jul 22, 2001 | 01:32 PM
un4givin89's Avatar
who the hell are you? Why don't you go shove it up your ***
Old Jul 22, 2001 | 01:39 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:
who the hell are you? Why don't you go shove it up your *** </font>
Why dont you?
Old Jul 22, 2001 | 01:40 PM
Guest
Guest
Posts: n/a
Oh and I guess you can dish it out but you cant take it huh? Still wet behind the ears arent you? Child.
Old Jul 22, 2001 | 01:41 PM
un4givin89's Avatar
What in the hell are you talking about? Have I offended you some how? If you want to call me a child why are you droping to my level??
Old Jul 22, 2001 | 08:52 PM
Guest
Guest
Posts: n/a
You asked:
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:YOU LET YOUR CAR GET THAT HOTT!! DON"T RUN IT OVER 220 JESUS H ChrIST</font>
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:you took it somewhere? And you paid money, damn your stupid. Go buy a battery re-charger for 15 bucks. You never know when you'll need it. Good investment.</font>
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:if you don't know what fuel injectors are, you shouldn't be going around changing your gas. Go get a book and learn more about your car first.</font>
This was edited to something less offensive:
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:always pay more attention you take something off. Make a note of its postion, take a picture or mark your bolts and there places, i find fingernail paint works great cuase it comes off easly.</font>
It read something like this originally:
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:take a picture next time or go get a manual for your car.</font>
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:this subject title gets puts my mind in the guter.</font>
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:just get your 12 gauge out, start shooting into the engine. then get some ligther fluid and poor it all over that car and light it. Allow it to burn for 1 to 2 hours then let cool.</font>
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:to the accesories in the fuse box silly. Run the ground to any black wire or any metal part of the car duh.</font>
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:If the car only goes a 110 then DUH!! Actually this sounds like what is known as the speed limiter in TBI equipped
F-bodies. Mine had this problem too.
</font>
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:They why the **** did you buy it??</font>
I didnt check all of your posts, but a few. Generally, helpful responses with no attitude are nice. Responses with attitude are completely unnecessary and wont be tolerated if you keep it up. I figured you didnt like being treated that way, so I posted to make sure and what do you know, you can dish it out but cant take it.
I suggest you lose the attitude.
Old Jul 22, 2001 | 09:51 PM
un4givin89's Avatar
Umm, I don't have one. Most of those I noticed you re-edited to your own taste and took out of context in a joking manner like the shoot it with a 12 gauge, that was a joke, or the thing about the fuse box, joking round there too. I don't like being pushed around by some stuck up, who happens to be a moderator. Write me a email if you think I'm outta touch.
Old Jul 22, 2001 | 10:19 PM
TransAm383's Avatar
At the risk of sounding like a follower, Im with madmax. Theres no need for attitude. Theres people of all different skill levels around here. Some have been into the hobby for years and some are just getting started and its real discouraging when some jerk starts shooting his mouth off. Im sure at one time even you had a few "dumb" questions. Or have you always known everything there is to know?
Old Jul 22, 2001 | 10:28 PM
un4givin89's Avatar
nothing more from the peanut gallery
Old Jul 22, 2001 | 10:41 PM
Guest
Guest
Posts: n/a
Edited? Not. And by the way those are copies of the entire text you wrote in those posts, 100% unedited except for the one I said that you had edited this morning about the power steering.
Keep it up, and I'll tell Dirk to take care of you.
[This message has been edited by madmax (edited July 22, 2001).]
Old Jul 22, 2001 | 11:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Hey un4givin89,
Don't feel bad. It's just the type of humor you have that can be easily taken the wrong way. I kinda have the same sense of humor. Not quite that harsh, but I can tell when you're joking. Maybe if you just tried answering the questions first, then throw in a joke that doesn't contain the words "stupid", "jerk", or "duh", then it wouldn't be taken the wrong way.
I can tell you that I'm on the other page. I try and help people on here, then some other "know it all" (I dunno who )comes along and tells me I'm a moron, or stupid, and it ticks me off. AT LEAST I TRY AND HELP!!!! Isn't that what we go to this site for? To help and be helped?
"Well why don't you just do it this way?" is a response I get a lot. Obviously I didn't think of it that way, or don't know enough about it to think of any other way. If I did, I wouldn't need to ask, or I wouldn't tell another guy that I'm not 100% sure.
Just remember that it's not always what you say, but HOW you say it.
Old Jul 22, 2001 | 11:07 PM
un4givin89's Avatar
subject cleared [July 23, 2001 3:23:45 EST]
[This message has been edited by un4givin89 (edited July 23, 2001).]
Old Jul 22, 2001 | 11:18 PM
un4givin89's Avatar
AJ_92RS
can't help but be a southern born and raised red neck, always offends the leberals
Old Jul 23, 2001 | 01:17 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Well I guess we got a little off topic there, huh. I see both points and I feel both points were made. Now can anybody tell me which is the best open air filter for my '86 305 4bbl 700tranny. I am a layman in this area and need all of the info available. Thanks
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Jul 23, 2001 | 01:40 AM
Tas's Avatar
Tas
for TBI, do not get Edelbrock. All the ones I found are drop base. Get a flat base one like a Mr. Gasket or a P.A.W. brand one like I did or similar non-drop base. http://www.pawinc.com/ I used paper filters until I decided what size was good FOR ME. Once I did, I got a K&N for it.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 23, 2001 | 09:24 AM
un4givin89's Avatar
why shouldn't you use a drop base for TBI??
Old Jul 23, 2001 | 10:05 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I just opend this thread, I just *knew* there was more to it than an open element discussion
Old Jul 23, 2001 | 10:27 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
If you use a flat base air cleaner you can get rid of the air cleaner spacer. This way, the incoming air can come in from the sides of the injectors rather than having to come straight down and around 'em. The flat bottom air cleaner will do the most good if you grind down the ridges around the throttle bores.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Jul 23, 2001 | 11:30 AM
un4givin89's Avatar
I'm guessing the proccedure is bout the same, but varies from person to person and there experince
Old Jul 23, 2001 | 12:13 PM
Guest
Guest
Posts: n/a
No, you didnt step on my toes, in fact if you did I could care less, I am just looking out for others. A few of your replies were uncalled for, and it seems you are aware of that, so I guess the issue is cleared up.
Ditch the spacer ring on that TBI.
BTW, you really should take your name and phone number off that post up there, no telling what some people might do with that information.
[This message has been edited by madmax (edited July 23, 2001).]
Jake_92RS
Jan 28, 2020 10:37 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
gta90
Sep 15, 2015 04:00 PM
wruiz
Aug 13, 2015 09:07 PM
