Still don't know which rockers to get...help
Old Jul 22, 2001 | 03:29 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Ok I need some p/n's here. I want either 1.5 or 1.52 rockers for my car that are roller tips. I don't need self aligning because I have guide plates and I don't want to spend a fortune. I would also like to not have to modify the centerbolt valve covers. Please help I need to order soon.
Old Jul 22, 2001 | 03:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you want roller-tip, not necessarily full roller, use Comp 1412s.
I don't know of any roller-trunnion rockers that will for sure go under all stock vlave covers.
ICON Motorsports
Old Jul 22, 2001 | 04:22 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I've seen and read the Crane Gold series will fit. I know they advertise the self aligning ones, so I assume that the regular ones will also. But they aren't cheap. I think like $300 for a set. They're the ones that GM used on the LT4, so I'd say that they're strong.
Are the Comp 1412s the Magnums? I've been interested in those because they seem like a good middle-of-the-road option. Anyone have them? Good luck with them?
Old Jul 22, 2001 | 04:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have a set of their 1.6 brothers (1416) that has run over 100,000 miles... I doubt any aluminum rockers will ever do that... I don't know what Paul is doing with his car, but if he wants to drive it a whole motor lifetime on the street, steel is the way to go.
ICON Motorsports
Old Jul 22, 2001 | 05:46 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
The roller tips arn't going to help alot since 99% of the advantage of a roller rocker is in the trunion. Actually some of the roller rockers are going to a 'radius' or fixed tip since there's little friction on the tip anyway... You would be better off cash-wise getting plain stamped long slot rockers with grooved pivot ***** in a 1.6 ratio.
Old Jul 22, 2001 | 09:40 PM
Car: 89 IROC-Z
Engine: 383
I'm pretty sure the 1412's are the Magnums...and they are the standard (non-self aligning) ones. I think this is what I'll get unless someone else convinces me before tomorrow night not to.
Old Jul 22, 2001 | 11:26 PM
AJ_92RS's Avatar
I figured as much about the roller tip part. I just know that the quality of steel that CompCams uses helps keep symmetry in the alignment of the parts from less deflection. I can't imagine that the roller tips would hurt though, right? Better safe than sorry. They may not help a ton, but they gotta at least reduce friction to the point of less heat on the valve tips. Even that is a plus.
Not trying to post an argument, but you can't say that roller tips don't help at all. Just maybe not as much as you'd think, that's all.
AJ
[This message has been edited by AJ_92RS (edited July 22, 2001).]
Old Jul 23, 2001 | 12:07 AM
Black82Z's Avatar
I believe that in jeg's or Summit, you can order a set of 8 1.5 and 8 1.6 rollers. In my opinon that is the way to go. I was reading a book called modifying small block chevy valvetrains, and in this book it states that the roller rockers are worth about 10 hp if the same ratio (due to less friction and better ratio accuracy compared to stock) and are worth about 15-20hp if a higher ratio is used( 1.6:1)
----(these figures are on a stock cam with stock heads--- if other variables are present number will be different)----
It then goes on to state that if a dual pattern cam is used and ported stock heads or upgraded heads are used the best gains are shown through 1.5:1 rockers on the exhause and 1.6:1 on the intake
---(I figure this is stated with little or no exhause back pressure)---
This is what the book says, I have no real world experience with this and if someone does please confirm my reply, thank you
82 Z28 have LG4-305"
Rebuilt heads-3 angle valve job,ported and gasket matched. edelbrock performer, chevy 1.6:1 roller rockers,MSD6AL, rebuilt carb,15x4" K&N
3"flowmaster american thunder, Mac high flow cat,headman headers,
700-R4--B&M shift kit, B&M tranny cooler.
Sub-frame connectors, boxed lower control arms and torque arm. 1.5" front sway bar, new BFgoodrich radial T/A's--215/65 front 255/60 rear
RADIO-- premier Deh-p300
2-10"kicker SPLs,ZR240,premier 434x(4 way), custom built fiberglass box for subs. pioneer 6X9 & 4X6, grant GT steering wheel
Old Jul 23, 2001 | 12:41 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the 1417 is the one your looking for in comp cams. the roller tip saves alot of wear and heat from the valve tip. of course there are other brands, but that's the best roller tip set up out there.
Old Jul 23, 2001 | 12:16 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have the Crane Gold series narrow body 1.6 roller rockers (got them from a friend unused for a good deal otherwise not sure if I'd have spent the $$$ on them) and they fit under my stock valve covers with no problems. My TFS heads came with a raised deck height (.1") for the valve covers to give more room for large aftermarket rockers but I had these on a stock headed car as well with no problems with valve cover clearance.
I would suggest getting some cast aluminum valve covers if you go with full roller rockers as they get a bit noisey at times and the thicker aluminum is much better at keeping the rocker noise down.
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, BBK 52mm TB, Edelbrock TES, gutted Cat, Flowmaster, CAI w/K+N cone, AFPR, TB bypass, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Alum. Driveshaft, Hotchkis STB.
Coming Soon!!: Fourth gen 3.42:1 rear, Spohn LCAs and Panhard, '99 Camaro seats.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
