Weird Timing
Old Jul 24, 2001 | 06:06 AM
gremlinz28's Avatar
Weird Timing
For some reason, my car will not idle under 12 degrees advance. I have it set at 12 initial and 35 total degrees with the vaccum advance unplugged. when I move the distributor under 12 initial, the motor dies. I know I have a good size vaccum leak from my brake booster because I can press the brakes and the idle jumps up about 200 rpms. Could the leak have something to do with the timing? The tab seems to be right because when I put the #1 piston on TDC, the mark was on "0". The car runs perfect, but was just curious why it won't idle under 12 degrees advance. Heres whats been done to the motor in case you need this info:
350 +.040
290/ .460 lift cam
stock vortec heads
performer intake
demon 625 carb
10:1 compression
HEI distributor
Any insight would be helpful!!!!
Thanks again,
Jason Gamlin
'86 Iroc
350 5-speed
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
EFR2000
Aug 18, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
novaderrik
Aug 10, 2015 12:44 PM
