Help me!!! Engine trouble!!
Old Jul 24, 2001 | 09:30 AM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
My 305 IROC has recently started giving me some problems. The engine note has changed drastically, there is a slight hissing sound when accelerating, a gauge mounted to my intake (possibly to the fuel rail, but im not sure) is going completely nuts, fluctuating from 0-65 psi completely at random, and when last I gave it heavy throttle, there was profuse smoke from the side of the engine- a leak of some sort hitting the header (I could hear the sound of something hitting it then evaporating). Now, I have been told I could have an intake manifold leak or a head gasket leak. I dont think it would be a head gasket problem, because I have been told that if the car sits overnight on a level surface and you check the oil level in the morning, coolant would be noticeable on the dipstick if the head gasket was leaking. HELP ME!!! What do I do? I like my 'roc too much to have it not moving (well, it moves, just not as fast)
Old Jul 24, 2001 | 09:49 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Poor performance, hissing through the exhaust, really sounds like the exhaust is restricted.
Plugged cat, smashed pipe, etc...
backtothe80s
Sep 5, 2015 12:39 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
