nonthirdgen-88 cutlass ciera rack and pinion.
Old Jul 24, 2001 | 01:51 PM
BenDoe's Avatar
I have an 88 cutlass ciera and the Les Shwab told me that the rack and pinion needed to be replaced because of an oil leak. I want to do it myself, the question is, could i just replace the seal, or would i have to replace the entire unit. If i have to replace the entire unit, are there any special tools required? How long of a job is it?
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 self-burned eproms.
Gained 20HP by porting and polishing my EGR passage.(some people take this seriously)
All work done by myself, and proud of it!
Find a .bin on the internet and want it burned? I'll do it for you!
Old Jul 24, 2001 | 10:26 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Just replace it.
Its kinda a PITA on most FWD cars, (I can't recall that car specifically), the toughest part usually is getting the column bolt disconnected and reconected, there isn't much room in there.
Other than that, just a couple of lines and tie rod ends...you will need to get it aligned afterward....
Your biggest prob is the lack of work space.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Terrell351
Jun 13, 2021 01:13 PM
Ed1LE
Sep 30, 2018 09:14 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
gord327
Oct 3, 2015 01:25 PM
SG91camaro
Sep 5, 2015 10:27 PM
