Serpentine Belt/Smog Removal, tech artical...
Old Jul 24, 2001 | 11:28 PM
EO273KiD's Avatar
I was going to remove my smog pump... but the bottom picture on the tech artical page, doesn't have a power steering pump.... so, I was wondering if you use the same belt as mentioned in the artical if u still have it..
Old Jul 25, 2001 | 02:39 AM
makinemtap's Avatar
i just did it tonite..used the 96.8" belt, and it worked fine..i routed it the same way shown in the article, now i just have to remove all of the lines, and plug the AIR line coming off of each manifold..but yes, the dayco belt i bought is 96.8" and is 6 rib..pn 5060968
Old Jul 25, 2001 | 05:53 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Go to this link, and see the belt routing diagram: Belt Routing
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
greenyone
Sep 8, 2015 08:41 PM
