HELP QUICK!!! Car is Sputtering?????
Old Jul 24, 2001 | 03:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I started my car today, it idled fine, but when I give it gas the car sputters through the exhaust. Could it be water in the gas perhaps, what else should I check. I smelled gas when I was revving it in park. I need to get this fixed, I have to drive 200 miles home in like 3 days.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage
"There is nothing more addicting than speed"
Old Jul 24, 2001 | 03:49 PM
Car: 99 Formula
Axle/Gears: 342
Also I noticed that around my PCV there was a little bit of oil, could that be going bad and cause this problem. I had a similar problem a while back. On valve covers I only had the T-handles that stick up with no guide plates. So I put one hold down on each valve cover(they were just laying around), and the sputtering went away. This weekend I actually bought enough hold down plates for the valve covers, could I have overtightened the hold downs.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Old Jul 24, 2001 | 03:54 PM
Car: 99 Formula
Axle/Gears: 342
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Old Jul 24, 2001 | 05:25 PM
Car: 99 Formula
Axle/Gears: 342
OK, this may sound like a stupid question, but should the PCV valve have a slight smell of gas to it. I checked all the hoses running to the carb and there should be no vacuum leak.
Another thought I had was, lately my car hasn't been pulling as hard, I know it could be several things, but I was thinking could my fuel filter be clogged which has gotten worse and making my car sputter on acceleration.
Old Jul 24, 2001 | 08:24 PM
Car: 99 Formula
Axle/Gears: 342
I replaced the PCV valve, no luck. Anyone have any ideas, the car idles kind of rough now, at 600 rpm's but doesn't drop below 500 rpm's.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Old Jul 25, 2001 | 09:39 AM
Car: 99 Formula
Axle/Gears: 342
anyone????
Jorlain
Aug 24, 2022 05:11 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
L98GTA87
Aug 5, 2015 11:02 PM
