Engine died during WOT..now won't idle
Old Mar 30, 2005 | 12:33 AM
MidnightTorker's Avatar
Car: 1983 Z28
Engine: 350 CID
Transmission: TH-350
Hello,
I went for a full throttle blast.... during the "blast" the car cut completely out..... felt like I was out of fuel.... When I finally got it restarted on the side of the road.."felt embarrassed.... all the people I flew by where laughing" It would barely idle.... I had to limp it home... it wouln't take any throttle...BUT when i kept it in second.......and the RPMS came up to 2000 THE CAR RAN PERFECT!!!.... soo I punched it ....and it kept backfiring through the carb....
Got the car home... idles lower and sounds differently......lower tone............... barely runs until I hit 2000 .... then IT RUNS PERFECT.. until I hit aout 3500... then it runs like garbage ...if I give it full throttle ...it just shoots 2-3 foot flames out of the carb.....
I do have some good news...... I don't need to shave or get a hair cut for awhile......
350... 416 ported heads.. 3310 vac sec carb Holley fuel pump mech. 230/230 4.88 cam............... etc...
Accel coil
No broken springs or anything out of the ordinary....
Can't drive...
Any help would be awsome... thank you,
Rob..
Old Mar 30, 2005 | 01:10 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
ignition problem?
Old Mar 30, 2005 | 11:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do a compression test.
Old Mar 31, 2005 | 01:04 AM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
something wrong with the carburetor maybe?
Old Mar 31, 2005 | 10:42 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
great so we just covered everything. Im thinking ignition isnt it because its idling lower, and I dont think its fuel related because two sets of rpms are affected, and the fact that you say the tone is different is scary unless its just because of the lower idle. I think it sounds like valvetrain. Check all your spark plugs for some abnormal colors or wetness or oil!!. A compression test is easy to do if that checks out ok. So is taking off the valve covers. You didnt say if there were any strange noises coming from the motor. I cant believe more people dont have a response to this.
Old Mar 31, 2005 | 01:24 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Timing chain jumped?
Old Mar 31, 2005 | 07:07 PM
sellmanb's Avatar
Car: '86 Berlinetta
That's what I was thinking too... backfiring is typically a timing problem, and distributors dont just "turn themselves" typically (though there have been some cases where they wont stay set, but we wont go there).
Check your timing before you do anything though...
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
