what?
Old Mar 30, 2005 | 01:51 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
what?
ok i have a chevy 350 its carbed and has accel disttrubter, i was going to set the timing last night when i noticed this, i hit the harmonic balancer with the light and noticed that the numbers were lining up with the timing tab then all of a sudden the would jump and then come back down to the same spot and do it again now ive never used a timing light i just figuered i would give it a try but i dont think its supposed to do this?
Old Mar 30, 2005 | 02:02 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
if the motor shakes when younotice the jump in timing then its the engine missing.
Old Mar 30, 2005 | 02:12 PM
ede's Avatar
ede
est,vacuum or mechanical advance is moving it
Old Mar 30, 2005 | 02:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Or the timing light is picking up a signal from another cylinder.
Old Mar 30, 2005 | 02:27 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
well the distrubuter is really old and its got a biiger cam with a 443 in 440 ex lift i thought maybe it was the distrbuter and ive checked for all vaccum leaks there isnt any, ive been having problems with it because i cant seem to get it timed right and the car lacks tons of power and when u open throttle to fast the car dies what coiuld this be caused from and im running just a stock torque converter.
Old Mar 31, 2005 | 12:57 AM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
Originally posted by 350WHT
when u open throttle to fast the car dies what coiuld this be caused from.
if it is carburated, it could just be cold other than that, i don't know, thats the best i can come up with. lol
Old Mar 31, 2005 | 08:57 AM
five7kid's Avatar
Replace the cap, rotor & wires. Most likely you're leaking spark from one of those sources. Since it's down on power, might as well replace the plugs while you're at it.
Old Mar 31, 2005 | 06:55 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
could a module made in the dist to run off the computer be causing it if i dont have a computer anymore.
