play in balancer?
Old Mar 31, 2005 | 12:27 AM
Kandied91z's Avatar
play in balancer?
if you pull on your balancer and notice play in the crank what could that mean? how much play becomes dangerous? what can cause such type of play?
Old Mar 31, 2005 | 12:39 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
in the crank there shouldn't be 1 mm of play, mine was solid as a rock in all 3 engines i've worked on, i think its the bearing but i'm not too sure
Old Mar 31, 2005 | 12:44 AM
Kandied91z's Avatar
just curious, i was having this discussion with someone about possible play with the crank and how it could be the thrust bearing. just trying to figure out what causes play? what can be damaged as a result and what is damaged to cause the intial play.
Old Mar 31, 2005 | 07:26 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
You have a bad thrust bearing or worn thrust surface on the crank. This can be caused by many things including a bad torque converter on the auto's .005-.009 is typical end play(thrust) on crank
Old Mar 31, 2005 | 01:13 PM
Kandied91z's Avatar
and you would notice this when things are all together by... ?
thanks.
Old Mar 31, 2005 | 04:07 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Side stepping the clutch at 6K rpm's .
The thrust bearing or the surface on the crank where it rides could be worn due to repeated activity stated above. Easiest way to measure is after installing the crank. Use a dial indicator and tap the crank back and forth. I think this is a much bigger problem with stick cars than autos because releasing the clutch when racing slams the crank hard.
Old Mar 31, 2005 | 05:53 PM
ede's Avatar
ede
silly question time. are you sure the play is in the crank and not the dampner?
Old Apr 1, 2005 | 02:39 PM
Kandied91z's Avatar
very well could be. i don't even know if there is play in the balancer. asking for a friend whom doesn't have a computer. he asked me the question the other day and i had no idea of an answer for reason.
thanks alot everyone.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
rusty vango
Sep 29, 2015 02:44 PM
monte87cortez
Sep 26, 2015 08:10 PM
Magman
Sep 13, 2015 12:14 AM
