quick question on power window motor removal.
Old Mar 31, 2005 | 03:40 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Read the tech articles and did some searching but have one quick question I didn't really get answered. Will it be any more difficult/easy to replace the motor with the window rolled all the way up? Since that is how my motor failed I cannot lower it to the half way position. Can I still go about changing it the same way??
Old Mar 31, 2005 | 03:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
When you drill the holes in the one door layer and then drill or grind the rivets out from behind that, and the motor falls out, the window will be free to move. Then you can put it wherever it needs to be so that you can snake the motor out of the door.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
