engine really rough
Old Jul 25, 2001 | 11:44 PM
firbird's Avatar
engine really rough
I cannot get my engine smooth. I have just installed a new 350 in my car and when i turn it over it can idle but it is very rough and shakes a lot. I adjusted my timing and got it about as good as it could get by turning the distributor i also unconnected the EST when i did it. I am very sure that all my spark plugs are one tight but i have been wrong before so i will check that in the morning but what else could do that because i don’t know what to do.
Old Jul 26, 2001 | 01:40 AM
Enkil's Avatar
Vacuum leaks will cause a rough idle, so check all your lines. It's probably the cheapest fix, so, why not?
Check your idle air passageways, when they get clogged it can cause poor idle as well.
While you're at it, set/adjust the IAC and TPS. That can cause poor idles too.
A bad EGR valve can cause a rough idle, although unfortunately it's about 80 bucks.
A radical cam can also produce a rough idle, but I"m guessing you would've known about that if you swapped cams. heh
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 26, 2001 | 04:59 AM
firbird's Avatar
That is all very true. I checked to see if i have any vacuum leaks all around and don’t think i do. This is a new engine with mostly new parts on it. And it does not have an EGR, i just plugged the vacuum port, is that how you do it? And i really wish i had a rough idle because of a big cam . Oh yea how do you set/adjust the IAC and TPS i really don’t know and if someone could tell me how i would appreciate it.
Thank,
Danny
Old Jul 26, 2001 | 09:57 AM
Enkil's Avatar
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
There ya go. hehe. If you have any further questions just ask.
Old Jul 26, 2001 | 01:04 PM
firbird's Avatar
should have checked there first
thank you
Old Jul 26, 2001 | 01:19 PM
firbird's Avatar
1 question. how are you soposto mesure it when it has 3 wires comming off of it.
Old Jul 26, 2001 | 01:47 PM
firbird's Avatar
: eek: i was looking thought the tpi set up that i have in my garage and found out it has the same clip as my new tbi and i noticed something else... i had the wires back words i had the wires black blue white when there soposto be reversed. i had to make my one clip because i couldnot find another and asked someone what was the order and they told me backwards or he just took it off and having it faced towards him read the colors i did the colors when it was plugged in looking from the back where the wires come out!! Oh well i have to check it again to see if it will idle worth anything but i think that should help a lot
Frozer!!!
Jan 19, 2024 04:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Bradsaundry
Aug 12, 2015 12:34 AM
