-O2 Sensor-
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
-O2 Sensor-
I am getting SLP 1 5/8 headers for my L98. These headers will have AIR and O2 sensor fittings to keep the car emissions legal.
My question is: To put the headers in, the oxygen sensor will be coming out. While it is out, I figure I should just get a new one to avoid having to do it later... is there any specific one I should get? I don't know much about these things. Will any specfic type of sensor give me any gains?
***The driver formerly known as 89IROCZ***
1989 Chevrolet Camaro IROC-Z
350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back (currently no muffler, sounds on webpage), SLP 1 5/8 Coated Headers on order, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, throttle body coolant bypass, Spohn SFC's on order, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info, pictures and sounds (of the IROC) available on my webpage: http://go.to/iroc-z
AOL IMer: GPA 0point0
2.8 MPFI, no mods
I just got my new one from my local Napa, and it works great. All of them are pretty much the same.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'd step up to a heated sensor since it will sit farther away in the headers than it does in the exhaust manifolds. By being heated, it will perform more accurately in the cooler environment. In addition to the single wire, it just comes with 2 more that you need to hook to switched power and ground.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Transmission: Pro-built 700R4
<font face="Verdana, Arial" size="2">Originally posted by Jim85IROC:
</font>
</font>
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Does anyone know the part #for a AC Delco o2 sensor for a 89 5.7 GTA??
Thanks Sorry for posting under this post.
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Mike
This is supposed to be a heated O2 sensor:
25312184 $62.00
But I have never verified it.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
25312184 $62.00
1989 IROC-Z 5.7L
NOS 150HP kit
Got it! I drove the car for like 15 minutes and sprayed WD-40 and stuff, and it popped off (after bashing my knuckles into the alternator). I got the new one in an hour later because the engine was so damn hot. I just hand tightened it- that should be fine, right? Well my engine runs so smooth now. No more stalling, no check engine light, no RPM dips, and increased performance at higher temps!
daddy33
Jun 12, 2011 03:23 PM
