reinstalling heads
Car: 1987 IROC-Z
reinstalling heads
im putting the heads back on tonight, and i just want to know im not messing it up by picking the wrong bolt sealant. the only thing i have in my garage for sealant is "hi tack". is that stuff good for sealing head bolts? i always say the best way to learn is the hard way.... but i dont really want to learn this lesson more than once...
thanx
sunbound
thanx
sunbound
i use liquid teflon and that seems to be the prefered sealer for head bolts. i have used the non harding permatex in a tube and the permatex in a can with a brush in the lid, but as far as i can see nothing is better than liquid teflon sealer.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Yup, liquid teflon has worked the best for me. I've also seen RTV used but I still prefer the liquid teflon.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Car: 1987 IROC-Z
cool, thanx....
one more thing.... do the rocker arm retaining bolts have to be torqued? or just tight enough so the rocker arms dont move from side to side?
Car: Take
Engine: Your
Transmission: Pick
Uhh.... They are nuts, and you need to tighten them untill the proper "lash" is set. I say "lash" even though its really "preload" since it has hydraulic lifters.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
92projectcamaro
Jan 18, 2016 08:00 AM
theshackle
Aug 23, 2015 03:49 PM
