Need answer quick, about 1.6 RR's
Old Jul 25, 2001 | 09:21 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I need to order 1.6 rr's tonight to get 'em in time for the weekend. I have an '88 LO3 motor, and I'm going to mildly port the heads, put an LT1 cam in it, and want to install 1.6rr's. Will I need to machine anything to add the 1.6 rr's? I called Jegs and they said I need to machine the heads for it? I have no clue, do I need to do anything special to add 1.6 rr's? Please help.
Old Jul 26, 2001 | 01:46 AM
Dan87IROC-Z's Avatar
If your new cam with the lift of the 1.6 rockers is over, I think .480" lift, you will need to have the valve guides shortened, or you will bend all your push rods the second you start it.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 27, 2001 | 01:53 AM
Beefy89's Avatar
I'm running an LT1 cam with 1.6 roller tips and have not had any problems.
Shoot Shoot!!!!!
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
