Oil Pressure Gauge..where to tap into block?
Old Jul 27, 2001 | 01:56 AM
BahamutRS's Avatar
Where's the best place for me to tap this oil pressure into on my 305?
Old Jul 27, 2001 | 02:28 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The stock sender is right behind the intake manifold towards the drivers side. You could just remove the old one if you'rem not using it and tap in there.
Other places are on the drivers side above the oil filter. There's also a stock sender there (For electric fuel pumps) so if you're not running a carb, you'll need to tee it there to retain the stock sender.
I believe both taps are female 1/8" NPT
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
