Broke @ Track! LOUD buzz from fuel pump- is it what I think??
Old Jul 26, 2001 | 08:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Okay, so I broke at the track again... car was stumbling while I waited to go up to the tree, and stalled out after my second run. I finally got it started, but it still wanted to stall. If I kept the RPM's constant, and near 3000 RPM, the car would work fine. As soon as I dropped in RPM, or, if I jerkily played with the gas pedal, the car would stumble, cut out, almost stall, etc. I actually had the car floored (thinking it flooded), and the rpm's bounced around 300-400.
The fuel pump sounds like a very large & ticked-off hornet, I've never heard it louder! The thing almost sounds like it'll explode!
I got home (driving with two feet, brake & gas, and using 2nd gear and neutral), and put a fuel pressure gauge on it after the car cooled. I got 33-35... stock should be 40.5-49 PSI.
Can this be anything else besides the pump?? I haven't bothered to check the regulator or anything because of that loud pump noise; I don't see how a bad regulator would make the pump scream. I just replaced the Fuel Filter (as part of a major tuneup, all filters covered) on July 7th, a few weeks ago. I don't think it's a spark module problem, since the car runs at 3000+ RPM fine. I was thinking "clogged catalytic", but the car runs fine at 3000+ rpm.
I last replaced the fuel pump July 5, 1997. When my original pump died, it went out with a quiet "gurgle"- sounded like a sick motor- not a loud "scream".
That raises another question... I put a Borg-Warner "lifetime" pump in. Should I return it, and get another BW pump for free, or, should I spill the cash for a genuine Ac/Delco one?
Thanks in advance! I hope to do the job this Friday & Saturday... at least I've done it before so I won't have to figure anything out.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited July 26, 2001).]
Old Jul 26, 2001 | 01:47 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I would replace fuel filter again just because its cheap (and changing the pump is such a PITA) and pretty much the only other cause. I bad regulator won't change sound of pump but a clog in the line like a clogged filter would. Most likely its the pump and since you have lifetime guarantee I would go back with the same pump. You replaced in 97 right. 4 years isn't tooo bad for it. I have definitely seen worse.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jul 26, 2001 | 02:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Do you think the filter would've clogged that fast, though?
Old Jul 26, 2001 | 07:45 PM
Bort62's Avatar
My Question is, Why were you at the track with a V6?
j/k )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jul 27, 2001 | 09:30 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Anyone else have something?? I'm dropping the tank in a few hours; if you can save me the headache, that'd be great!
[This message has been edited by TomP (edited July 27, 2001).]
Old Jul 27, 2001 | 09:48 AM
GilmourD's Avatar
What I'm thinking is that it could be the regulator. Say the regulator started regulating at whatever pressure you're getting, that would be a restriction in the line, like the before mention clog. Try taking the regulator out of the line and see how much pressure you get without it.
Old Jul 27, 2001 | 10:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
True, I'll have to pinch the return line to shut the regulator "off" and check pressure then. That should tell me if the regulator's leaking... I suppose I should pull the vac line off the regulator and see if it's soaked with gas!
What a shame- I called around for that high pressure fuel-pump-to-body feed hose, and nobody has one in stock; if they order it, it would come by Tuesday. Looks like I'll be re-using that hose again... oh well, I guess I can change it later- but I really didn't want to wait.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
