Cruise Control Delete Gear??
Old Apr 2, 2005 | 10:09 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Hello.
I need help with a part. I read a post here a while back that gave a napa part number for a "coupler" that will connect the speedo cable and tranny cable together so the speedometer will work without the cruise transducer. I have a '82 TA and I no longer have the cruise transducer. Rather than piece it all togher I would like to just get this part that basically does the same thing as the transducer, minus the cruise function. Before you go and tell me to just buy a longer speedo cable, I'd rather get the coupling device right now for a quick fix. Unless my cables are actually worn, replacing them is a last resort. IF anyone knows what I'm talking about or has the part number I could appreciate it. I've been searching for a couple hours on here and kind find the thread!
Old Apr 3, 2005 | 02:01 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Cruise control is very nice to have I would just pick up another unit personally.
They make an adaptor to fix or splice two cables togather but I dont know what the # is. You might consider just replacing the entire cable upto the the speedo head. They sell universal replacment cables for $10 in the help sections in most parts stores.
Old Apr 3, 2005 | 03:27 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
yah, I got ahold of a guy on this board a while ago. He said he had some Firebirds he was going to part out. He had an '82 and I told him I wanted all of the cruise control parts. Last I heard from him he said he got them out for me, but I haven't been able to get ahold of him since. I was going to just hook it back up again.
Old Aug 21, 2006 | 10:28 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Sorry to dig up this old thread but im trying to figure out what this thing is for. Is this a pic of that thing your talking about?
Old Aug 22, 2006 | 01:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's not what he's talking about. The cruise control govenor is under the hood up by the front driver's side corner.
What you have there looks like a vehicle speed sensor. I've never seen one like that, I would guess it is some sort of aftermarket piece for some type of add-on cruise control or computer of some sort.
Old Aug 22, 2006 | 07:25 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I've seen those before. They are special speed sensors for vehicles that run SBC fuel injection that require an electronic VSS, yet at the same time have a cable-driven speedo in the dash. That part allows the ECM to receive input on the vehicle's speed, without having the requirement of converting a mechanical speedo to an electronic version.
Old Aug 22, 2006 | 07:46 PM
Car: 84' Trans Am
Its like a yellow sensor that has braided wires going into this thing called electronic transmission module, the module has sensitivy adjustments for who knows what and has power and engagement lights? I bypassed it cuz the smaller speedo cable snapped and couldnt find an replacement, still it works without it hooked up.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
