water pump question
Old Apr 2, 2005 | 05:02 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
water pump question
i installed an older 350 in my car and it came with a new water pump, the only prob is the outlet on the wp is way bigger than the inlet on my radiator. i am using a v belt setup and an alt. is my only accesory. i was told to use a wp for a 86 model because it would have the small outlet and have the right rotation for my v belt setup. i want to mount the alt. on the passenger side with just a regular alt bracket, will this bracket work with an 86 style water pump or should i just go a different route. this is mainly a going to be a drag car and simplicity is what i am looking for. tia
Old Apr 2, 2005 | 05:27 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
About any of the old water pumps have the outlet bigger than the radiator connection, when you get a hose it will be swelled up for this. I believe the pump should work ok for the alternator as long as the brackets are for the newer long style pump.
Old Apr 2, 2005 | 05:37 PM
bubbz89's Avatar
Car: 1990 RS
do they make those hoses for my application?
Old Apr 2, 2005 | 05:40 PM
sellmanb's Avatar
Car: '86 Berlinetta
My alternator didnt hook up to my water pump at all IIRC (could be wrong though, been a lil since I removed it), the biggest problem in mounting my alternator was that the intake I was using didnt have the accessory hole on it.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
