Engine Problems!!!
Old Jul 26, 2001 | 10:29 AM
IROC-Z4ever's Avatar
Car: 1986 IROC
Transmission: TH700r4
Engine Problems!!!
Yesterday I found out that I blew a Rocker stud and repaired it. I thought that I put it in the Number 1 firing postion. Well I guess I was wrong and now the car will crank over but the shut down after a second. Someone please tell me what to do!!!!!!!!!!!
86 IROC-Z
K&N air filters, Air foil, hypertech chip, Edelbrock victor Jr. Heads
soon: 6-speed, rebuild 305, exhaust, fiberglass body.
Old Jul 26, 2001 | 04:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
First, what did you remove in order to get the valvecover off? Could be as simple as an airleak in the MAF ducting to the TB.
Did you reset the lash on all the valves, or only the one that you removed the rocker arm from?
You mention that you thought it was at #1 firing position, why is/was this a concern? Did you pull the distributor for some reason? Did you remove all the plug wires? If so, start by checking the wire routing first, if the dis was pulled for some reason, you'll need to verify that #1 is at TDC, and wores routed according through the firing order.
But start simple first.
Old Jul 27, 2001 | 02:11 PM
Car: 1986 IROC
Okay I got it starting the only thing is that it knock. I think its a valve but what do you guys think?
86 IROC-Z
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
