Intake Manifold Bolt Question...Odd.
Old Jul 27, 2001 | 08:19 PM
JETHROIROC's Avatar
Hey guys. I pulled my TPI base the other day and the back two bolts on the passenger side (#8 cylinder) that go through the coil and EGR solenoid bracket had a burnt crust on them and smelled of gas. I wouldn't think anything of it but none of the other 10 intake manifold bolts were this way. I had oil or antifreeze on some, but no burnt gassy crust. What gives? Thanks a bunch guys.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Jul 27, 2001 | 10:20 PM
Vader's Avatar
JI,
You may have extra fuel from an injector leak/flow problem on that cylinder. Testing injectors for leakage once they intake is apart is really quite easy. Just reconnect the fuel lines and injectors to the rails and energize the pump. A leaky unit will be fairly obvious.
Make sure you use a proper sealant on the bolts when you reassemble as well.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 28, 2001 | 06:41 AM
JETHROIROC's Avatar
Thanks Vader. I got some Accel 23# injectors four months ago and installed them, and the reason I was into the intake manifold was because I had one that leaked. But it was on the #1 cylinder. I did the injector test with the rail pulled from 40 to 62psi with the AFPR and #1 was the only one I could get to leak. It's possible, however, that the bolts got that way during the 10 years the old injectors were in there. I was thinking something was wrong with the head, but who knows. Oh well, at least I got to port the base and I'm getting ready to paint her Daytona yellow! Thanks again, Vader.
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
