84 L69 throwing CODE 23
Old Apr 5, 2005 | 12:58 PM
BlackSunshine84's Avatar
Car: 84 Z28
Engine: 305 H.O. (L69)
After putting on new plugs, wires, cap/rotor, started my 84 z28 L69 4bbl for the first time in a while and it threw code 23 which is either for throttle position sensor(does a carbed car even have that?) OR low intake temperature at manifold or something. Where is that located? Light then went out after I took the air filter completely off the carb and started it up. Is the plug thats on the front of the carb related to that at all cause i think it was just a bad connection and i may have knocked something loose. What do you guys think? Thanks.
Old Apr 5, 2005 | 01:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No air intake temp on carb'd cars.
Front driver's side corner of the carb is the connection for the TPS.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
PurelyPMD
May 5, 2016 04:57 PM
BumpaD82
Feb 26, 2016 02:57 PM
ndndndnd
Sep 28, 2015 08:00 AM
Lmancha96
Sep 25, 2015 08:11 PM
