Motor mounts
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Motor mounts
Does anyone know the torque specs on the mount to crossmember bolts? How about the big long bolt that goes through the rubber part? I believe the 3 bolts that hold the bracket to the engine block are 80 ft-lbs; those are the only ones listed in the Haynes manual I have. Any information is greatly appreciated.
Just use typical torque specs for the size fastener. Torque the bolt/nut to about 75-80% of peak torque and forget about it. Obviously, the table included is for steel threads only, and bolts threaded into cast materials or white metals should be regarded differently.
s and data for Drills. taps, and bolts is in this file:
Drills, Taps, and Bolts.pdf
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
