L98 questions
Old Apr 6, 2005 | 12:36 AM
SUPERPOWERS's Avatar
Car: 1982 Corvette
Engine: LS3 Stroker
Axle/Gears: 4.11
L98 questions
I am buying a motor from someone. He says that it is a L98 but he doesn't know what year camaro it is out of, he thinks that it is from 87-89. I believe him when he says that it is a L98 but I want to make absolutely sure. If I get the casting numbers will I be able to tell that it is an L98 350 motor?? Also the only special thing about the L98 motor was that it has a roller cam and lifters correct? Anything else?
Also I am putting this in my 85' IROC that currently has a 305 TPI in it. Will everything transfer over ok? I know that I need to change the Knock sensor. Will I need to reprogram my ECU?
Old Apr 6, 2005 | 01:08 AM
subliminal's Avatar
Back of the block behind the head it will say 5.0 for 305 LB9 or 5.7 for L98.
Old Apr 6, 2005 | 01:43 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Gonna need a 350 prom, and the 350 injectors also. There are tons of guys that have done this swap on the TPI board I'm sure...
Old Apr 6, 2005 | 06:57 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
L98 was GM's code for a 350 motor, there will be No such identification the block only casting numbers which can be decoded on Mortec web site.
Old Apr 6, 2005 | 07:36 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The 350 I pulled out of my 88' IROCZ had the engine code behind the passenger head on a ledge: 14093638 Mortec shows 87-95, but that includes cars/trucks with carb, TBI, and TPI.
Old Apr 6, 2005 | 07:58 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I believe you will need to swap to the 86-89 165 ecm to run a 350 eprom as well.
Old Apr 6, 2005 | 08:11 AM
Car: 1982 Corvette
Engine: LS3 Stroker
Axle/Gears: 4.11
so is there any way to tell if it is the roller motor by the casting numbers? Or do I need to take it appart to tell?
Old Apr 6, 2005 | 08:32 AM
brutalform's Avatar
Date code will tell you if it is a "roller" block. In 86, one piece center bolt valve covers were introduced. Correct me if Im wrong. In 87, rollers were introduced. Some 86 blocks are set up for roller, but you would have to disassemble to check. Also in 87, the center intake bolt angles were changed. If you remove a valve cover, and if you have the aligning stamped steel rockers, it might be a roller. I say "might" because GM sells the dimpled rocker for all replacements now. They could have been replaced, but I doubt it.
Old Apr 6, 2005 | 08:52 AM
Car: 1982 Corvette
Engine: LS3 Stroker
Axle/Gears: 4.11
so is the TPI from my 85' going to work?? Since the angle changed??
Old Apr 6, 2005 | 08:57 AM
brutalform's Avatar
Anything can be made to work. If you can look at the replacement engine, and see the intake bolt angles, it will narrow it down for you on the year, providing the heads were not replaced. You can touch up the holes with a file, or die grinder on your intake. Does the replacement engine have the manifold installed, is it a long block, or what?
Old Apr 6, 2005 | 09:11 AM
Car: 1982 Corvette
Engine: LS3 Stroker
Axle/Gears: 4.11
I was told that it is a stock L98 long block from 87'-89' camaro or TA. So will I just need to make the center holes in my intake bigger? and it does not have the intake installed.
Old Apr 6, 2005 | 01:05 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Yup, i believe the angle you want to elongate them to is 72 degrees.
Disregard this last part of the post....wasn't thinking straight.
BTW...If you have a 305 TPI now, why couldn't you use the 305 intake? It already has the correct angle center bolts, right?
Old Apr 6, 2005 | 01:14 PM
Car: 1982 Corvette
Engine: LS3 Stroker
Axle/Gears: 4.11
that was my question. I was under the impression that my 85' 305 intake has different bolt angles than the 87'-89'.
I want to use my 85' stuff, I just wanted to make sure that it would work.
Old Apr 6, 2005 | 01:29 PM
brutalform's Avatar
Not sure about an OEM intake. I do know that the Accel, and TPIS bases do have the holes set up for either style heads.
Old Apr 6, 2005 | 07:47 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I can peek thru my heads into the lifter valley, although thy're fast burn aluminum head, If you can do this with L98 heads you'll se the spider lifter retainer if it's a roller.
Old Apr 6, 2005 | 10:50 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by SUPERPOWERS
...and it does not have the intake installed.
Perfect , look in the big pit on top of the block and see if there is a flimsy piece of metal that looks -loosly- like a spider bolted in there. Or look for dogbones, etc.
Old Apr 7, 2005 | 12:20 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Riiight, what he said.....LOL
It's a roller if you see anything like this...
(thanks to formulajokester for the pic)
Attached Thumbnails L98 questions-c-documents-settings-owner
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
