Vortec CPI wired to TBI
I realize this is the thirdgen site
, but you guys seem very knowledgeable about this stuff so...
I Just picked up a 97 vortec 350 for cheap to put in my 92 tbi truck, and I was thinking.... I may be on glue, but could I not just install a high pressure fuel pump, plumb in my MAP sensor and hook the existing two wire injector harness up to the 8 on the vortec intake in 2 sets of 4 ? I would have to reprogram the injector size in the PROM obviously, but it should essentially work as batch injection as I believe the TPI motors do. Throttle body seems to have the usual TPS and IAC so they should be fine.
Any comments/experience with this ? I realize I could buy the TBI/vortec intake but by the time I plumb in the EGR etc, seems this could work out much cheaper.
, but you guys seem very knowledgeable about this stuff so...I Just picked up a 97 vortec 350 for cheap to put in my 92 tbi truck, and I was thinking.... I may be on glue, but could I not just install a high pressure fuel pump, plumb in my MAP sensor and hook the existing two wire injector harness up to the 8 on the vortec intake in 2 sets of 4 ? I would have to reprogram the injector size in the PROM obviously, but it should essentially work as batch injection as I believe the TPI motors do. Throttle body seems to have the usual TPS and IAC so they should be fine.
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
everything i've read says stay away from the stock vortec cpi setup. something about the style of injection not being all the good for horsepower/modding. i believe it is a less reliable setup than tbi/carb/tpi.
i myself just plan on running the vortecs with a carb manifold and either the tbi body or something a bit more aftermarket (still in the building stages of my megasquirt setup)....
however, i dont plan on having an egr, so that may play a bit into your decision (havent had one in the last 2-3 yrs)
yes, thanks for the advice. I think I will end up going with a vortec/tbi intake and probably a holley 670 throttle body. I just thought that if anybody had done this with decent results I would give it a try since the throttle body/intake will probably run me $4-500 even for used stuff.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Car: 1983 G20 Chevy
Transmission: 4L60
Coolant leaks from the intake gaskets, the plastic upper intakes crack and allow vacuum leaks, finally the injector spyders go out.
