350 rebuild HELP
Old Apr 7, 2005 | 08:53 PM
DJMAD127's Avatar
Car: 87' pontiac formula
Engine: 350 tpi
Transmission: auto
350 rebuild HELP
i just got my 350 TPI in my 87 pontiac formula but have a problem. I have no idea were two line that come from the Vapor Canister goes, i have no open vacum opens and am lost on the correct place. Does andone got a diagram of all of the Emmisions/vacum line go?? i need help thanx.
Old Apr 7, 2005 | 10:03 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
The vac diagram should be on a sticker under the hood. I had the same question and just happend to look up and there it was. If not one of the canister lines runs over behind the over flow tank for the radiator, behind the alternator and connects to the right side of the throttle body. There should be two fittings on the right side of the TB. Upper goes to the PCV and lower goes to the canister.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
