cruise control
Old Apr 8, 2005 | 12:15 AM
jeregse's Avatar
cruise control
will set by pushing on the end of the switch but will not resume anyone know why and what is messed up?
Old Apr 9, 2005 | 06:28 AM
Vader's Avatar
It is quite possible that the slide switch ontacts in the control lever are failing or dirty. You can disconnect the wiring right at the base of the stalk and meter the switch for function and continuity. Remove the small cover from the side of the column and the connector will be readily apparent.
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
