Not Thirdgen ,how do you check for wear in a FWD wheel hub?
play, grease leaks, rough spots. not sure what to look for
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Ed,
Don't you mean a RWD hub (on a Fiero)?
As outlined above, there should be no lash nor should the bearing set coast when spun unloaded. There should be some preload on the bearings to prevent any radial or axial play, and this should also inhibit free spinning. There shold be no roughness or noise, and minor grease leaks are a sign that the bearings have been hot, wet, or are beginning to wear and allow some play.
Since many GM FWD (er, RWD Fiero) hubs have an blind flush outer race for the inboard bearing, there is not a good way to rebuild them unless you can get a real bargain on replacement bearings. A correct set will probably cost as much as a new Timken replacement hub (513011K Timken $76.99) by the time you weld to and pull the old races and install replacements. If you were doing a lot of them it might be profitable, but not for one-sies and two-sies.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
Car: 82 camaro SC
When they start to rumble, replace them.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
ok thanks guys, being the dumb *** that i am i was a little confused. a garage told my daughter she had a bad bearing in her car. i took the wheels off today to take a look and couldn't see, hear, or feel anything wrong. she said they never had the car on a lift, wheels off, or for a road test so i figured they were trying to make their boat payment this month.
Car: Take
Engine: Your
Transmission: Pick
Normally that "click" is the CV joints.
As for the bearing, usually you will get a "roar" or sometimes a "whine" noise from the affected wheel, and its speed related. If its on a FWD car, you can cut the wheel back and forth while driving, and the noise will come and go. (as the bearing loads and unloads).
I put one on my '97 Bonneville and it set me back over $200 (gotta go w/ the OEM parts
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
colton_carlson
Mar 8, 2019 12:21 PM
