Rist Pin repair??
Old Apr 10, 2005 | 12:07 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
Rist Pin repair??
anyone know how much i should be looking at for getting a Rist pin Fixxed my mechanic is almost sure thats whats wrong iwth my engine and he says its not really worth it to fix it when a new motor would be cheaper
Old Apr 10, 2005 | 01:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends what's wrong. New piston, resized rod and a bearing. Cylinder deglazing, new rings for the piston. You can keep adding to the list until you know exactly what's needed. Also required is a gasket set since the head has to come off.
It's hard to give an estimate for repairs of an internal problem until it's torn down to see exactly what needs to be fixed. For what it's worth, it's better to just drop in a new engine that way everything is done.
Old Apr 10, 2005 | 05:18 PM
ede's Avatar
ede
i'd suspect your mechanic has no idea what the problem is and is trying to sell you another engine that would fix your problem, whatever it might be.
Old Apr 10, 2005 | 05:49 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I agree. And I'll add to that, if your mechanic gave you a diagnosis of a rist pin problem, it was at best an educated guess. There's probably some mechanical noise coming from your block, and any way you slice it, it's going to involve taking your engine out to repair it. Or even to pinpoint what the problem actually is.
If there's a loud knock coming from your block, it might be repairable, but probably not without a rebuild.
Old Oct 29, 2010 | 09:45 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Rist Pin repair??
Holy old post brought back from the grave. This is from 2005...
Old Oct 30, 2010 | 12:51 AM
Be interesting to know how many cars and motors the d00d has been through since he asked about this.
Old Oct 30, 2010 | 12:58 AM
Antlocks's Avatar
Car: 82 Z28 .... 74 Nova
Engine: 350 Crossfire Injection....383 Sbc
Transmission: th350 ... 700r4
Axle/Gears: 2:73 Posi ... 3:42 Posi
i know right lol
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
