Hardware (bolts, etc.) question....
Old Apr 10, 2005 | 03:54 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Am I okay to use bolts and stuff from the hardware store for stuff like the alternator bracket, holding the pully onto the water pump, etc.? or do i need to buy automotive specific hardware? I'd prefer to go with like ARP or whatever but paying 7 or 8 bucks for 3 or 4 bolts just isnt worth it to me IMO....
Old Apr 10, 2005 | 05:08 PM
ede's Avatar
ede
i wouldn't use hardwear grade bolts. i use grade 8s from tractor supply store for 3.99 a pound.
Old Apr 10, 2005 | 05:29 PM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
I am not being smart but arent grade8 bolts grade 8 bolts I thought there was a standard and thats why the bolts are stamp they way they are.
Old Apr 10, 2005 | 06:12 PM
well you can buy grade 8 bolts from the hardware stores around here usually.....so thats what i was referring to.....
so grade 8 is okay for everything?
Old Apr 10, 2005 | 06:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yes grade 8 bolts from the harware store are the ones you want to buy. they're cheap and should work fine.
Old Apr 11, 2005 | 02:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I don't usually see grade 8's at my hardware store.
Just check the markings on the bolt head, the ones at the hardware store usually have no marks. Grade 2 right?
grade 5 = 3 marks
grade 8 = 5 marks
correct?
Old Apr 11, 2005 | 03:25 PM
ede's Avatar
ede
grade 5 = 3 marks
grade 8 = 5 marks
correct?
you got it
Old Apr 11, 2005 | 04:45 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
All grade 8 fasteners will be marked with the 5-slash marks. Those with no markings or just a mfg Id , I would not use for any stress or critical applications.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
drathaar907
Aug 6, 2015 04:20 PM
