missing and blue smoke...wreaks of fuel
Old Apr 10, 2005 | 08:30 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
hey folks..hows it going???.....hopeing someone can help me out here so here it go's
installed a new dist for my 88 350 TPI,and a Accel coil (same look as stock..its just yellow in color..bolts the same way as old coil did..OEM divorced type) I had already established TDC for # 1 earlier BEFORE I pulled out the old Dist.dropped the new one in did my best to have the rotor line up like the old one did...I can't get it to point right at the # 1 post on the cap....its either after it closer to the #8 post or before it just after the # 2 post..so i went with "closer" to #8 post..she slid right down in no problem...now i have a constant miss....and I see blueish type smoke out the back(worse when you raise the throttle of course)and i smell fuel...(rich) now i rechecked..and checked again my fireing order..18436572..clock wise..and its good..all wires are hooked up correctly.and the base timeing..is @ O' with wire disconnected..then reconnected after setting timeing(shut down before hooking wire back together)I have checked each injector and they are all ticking(of course doesn't mean they are squirting I guess) but am I a 'tooth" off????? in the dist gear??? i have not pulled any thing else..nor i have touched the plug wires yet.waiting for advise before I dig myself a hole.Man...MAN..I hope its not a valve problem...the blueish smoke has me scared.(hope its just unburn't fuel)never did this before the dist change.Old one came out do to corroded wires and such..it wasn't healthy..so i stepped up and replaced the whole thing.no codes btw.I hope this is an easy fix.... but I know you guys will get me pointed in the right direction,(HA..no pun intended)and I thank you for the help.OH btw..the miss is constant even when i rotate the dist counter clock and clock wise..stumbles real bad if I go to far counter and idles real low to stalling when I rotate to far clock wise.(advance and retard)
Brent
rndsout@comcast.net
Old Apr 11, 2005 | 10:25 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: missing and blue smoke...wreaks of fuel
Originally posted by 88355
...I can't get it to point right at the # 1 post on the cap....its either after it closer to the #8 post or before it just after the # 2 post..so i went with "closer" to #8 post..she slid right down in no problem... but am I a 'tooth" off????? in the dist gear???
Brent
rndsout@comcast.net
Can't be one tooth off, unless it's not engaging the oil pump drive shaft, or you're aligning the oil pump shaft to where you think the rotor should point to. The only other position the distributor can engage the oil pump shaft is 180° from the first one, if the oil pump shaft is still where it was when the distributor was pulled out..
The way the gear is designed, you can't drop it in straight down without re-aligning the oil pump shaft because the gear causes it to turn a little as it goes down for the last 1/2" or so.
Drop the distributor straight down about one tooth counterclockwise from where you want it, it'll be where it was before when it sits flush with the intake surface. If your a tooth of it's probably not sitting flush with the intake, if it is then there's a problem with the Distributor key/oil pump shaft slot engagement.
Old Apr 11, 2005 | 11:20 AM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
Thanks for getting back to me Garcia...I will re-check the dist install...and do it the way you just mentioned,maybe its not all the way down engaging the Cam gear like it should...I will investigate per your instruction.Will let you know.
Thanks again Garcia
Brent
Old Apr 14, 2005 | 04:30 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
Hello gain...well thanks for the help..its fixed!!!!! I noticed that the dist wasn't flush with the intake after all...I then tried re-installing it one tooth back like you mentioned and presto!!! good to go.Its amazing when you pay attention to detail
But again...thanks Garcia...for getting back to me and sheding some light on this for me.
she starts right up and purrs now like she should.
thanks again
Brent
Old Apr 14, 2005 | 10:50 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
have fun, later.
Old Apr 14, 2005 | 11:31 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
I love the feeling of those "EUREKA...IVE GOT IT" moments when you fix something....feels good huh?
Old Apr 16, 2005 | 07:03 AM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
You know??? It was funny(can laugh now)..as soon as I put my eye ***** right at the problem(dist not all the way in) I blurted out loud "AAA HAAA!!" " GOT YOU NOW" My kids were playing in the yard and came running over "whats wrong daddy???"LMAO. What a relief Garcia...I was starting to think I had a busted valve spring..or a valve problem,but thanks to your help.
Thanks again Garcia for your help.I have other issues with the vehicle that need to get fixed...but now the running part is solved,You may see me in here time-to-time posting away looking for advice.Will catch ya later.
Brent
sweet_87_iroc
Sep 25, 2015 10:01 PM
Linson
Aug 21, 2015 02:12 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
mustangman65_79
Aug 8, 2015 01:18 AM
