timing chain pissing me off
Old Jul 31, 2001 | 08:21 PM
rezinn's Avatar
Okay Im installing a new cam, cam is in and the crank gear is on. How am I supposed to get the cam gear and the timing chain installed the right way? I have it so that the two dots match up on the bottom of the cam gear and top of the crank gear because the motor has #1 at tdc. No matter how I do it, I can't get the cam gear on with the chain around the crank gear, the cam gear will never bolt on the cam the right way. Is there some trick to doing this?
Old Jul 31, 2001 | 08:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Then your #1 isn't quite exactly at TDC.
Move the crank slightly, until it works. Use a pair of great big pliers on the crank snout, CAREFULLY, so you don't tear up the key.
ICON Motorsports
Old Jul 31, 2001 | 08:32 PM
rezinn's Avatar
Thanks, I'll check it out after dinner.
Old Jul 31, 2001 | 10:21 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sometimes you have to back the crank gear off the crank just a little, so that both gears slide onto the crank and cam at a straight shot.
And FWIW, if the gears dots are lined up so the cam is at 6 o clock and the crank gear is 12 o clock, it is not TDC #1, its TDC #6...but that OK
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 31, 2001).]
Old Aug 1, 2001 | 12:29 PM
ede's Avatar
ede
i've always put the cam gear on last, with the chain o nthe crank gear and on the cam gear and just sort of work it on the dowel and bolt it up. it's like it'll fall right on when you have it lined up right but it'll beat you up if you don't.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
