Compression question
Old Apr 11, 2005 | 11:23 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Motor originally had 9.2:1 cast pistons in it with regular 350 iron heads on it, but now has Trick Flow 23* 62cc aluminum heads on it. . .
. . is there anyway to figure out the new compression?
Old Apr 11, 2005 | 11:40 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Do you know what size chambers you had with the 350 cast heads? Once you figure out the new static, subtract 1 point since they're aluminum and that's a rough mark of where your at.
Example, my block is fitted with 12:1 slugs based off 64cc heads. My AFR's ended up being 69cc so it took it down to 11.3
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
