Another timing question.
Old Aug 1, 2001 | 10:07 PM
Alan84TA's Avatar
I went to time my rebuilt 305 and I have a question. I hooked up the timing light to the number 1 plug but when I shine the light the mark is about 6 inches off to the right. As I adjust it and it get closer to the timing tab it starts running worse. Do I have the distributor off a notch or something? would it run like that?
Old Aug 1, 2001 | 10:09 PM
Alan84TA's Avatar
Sorry.. I ment the timing mark is off 6 inches to the left...
Old Aug 1, 2001 | 10:16 PM
Guest
Guest
Posts: n/a
Sounds more like the balancer slipped.
Old Aug 1, 2001 | 10:33 PM
R.O.B.'s Avatar
Like Madmax said, your balancer may have slipped. Or possibly you forgot to disconnect the distributor ecm wire.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Fronzizzle
Aug 19, 2015 01:36 PM
Bryan F
Aug 18, 2015 02:28 PM
wruiz
Aug 13, 2015 09:07 PM
jahblah
Aug 12, 2015 05:54 PM
